configure identity-management role delete dynamic-rule
configure identity-management role role_name delete dynamic-rule [rule_name | all]
Description
Deletes one or all dynamic ACL rules for the specified role.
Syntax Description
role_name
Specifies the name of an existing role.
rule_name
Specifies the name of a dynamic ACL rule to delete from the specified role.
all
Specifies that all dynamic ACL rules are to be deleted.
Default
N/A.
Usage Guidelines
None.
The following example deletes all dynamic rules from the role named India-Engr:
* Switch.55 # configure identity-management role "India-Engr" delete dynamic-rule all
This command was first available in ExtremeXOS 12.5.
The all option was added in ExtremeXOS 12.6.
Platform Availability
